Thanks for your reply.
I connected the remote controller app to mirror the screen and it seems to boot and then crash when it autoruns the PIA VPN app.
Will try the recovery steps.
I connected the remote controller app to mirror the screen and it seems to boot and then crash when it autoruns the PIA VPN app.Will try the recovery steps.
Ok, seems odd as it showing no signal on tv if you can view via the remote controller app, therefore a signal should be being sent to the tv, maybe you have a faulty HDMI cable in addition to the PIA app issue.
Do you by any chance have a usb/micro sd card or hdd plugged in? if so disconnect these and try powering up again. also DO NOT format any drive using exFAT file system as at the moment there is a bug that causes IPTVLauncher to crash, so format using FAT32 or NTFS, use FAT32 for manual recovery if you do that, so if you have plugged anything in disconnect and try powering up again.. So try this as well before manual recovery.
After trying the recovery steps I get the android recovery error image (red triangle). Anything else I can try? The mirror app stops working as the VPN app kicks in. So I am blind after that and I cant access the settings menu quick enough to disable it.
The mirror app only works when the box is booted up hence i mentioned try another HDMI cable as a no signal indicates hdmi faulty cable. Did you try another HDMI cable? it was step 1) in my previous post.
a red triangle indicates android has gone into recovery mode. At this point i would go through the manual recovery instructions and try again. The PIA app cannot launch until box has booted up past a certain level and if entering manual recovery it should not interfere at all.
Did you by any chance try to install beta firmware, it was temporary mentioned on this forum and then removed?
I am going to tag @SAM at this point to see if he can assist any further as i'm not aware of any other recovery method.
Ok, not sure what was happening but I managed to reset by quickly disabling VPN and then going to the settings menu and do it from there using the mirror app.
The box now boots fine, I think the problem might have been caused by the standby problem. Does anyone have a solution for that? I disabled any autostart app to make sure nothing boots when I start the box.
What is the problem with attached HDD in exfat? When I boot with the HDD attached it gets stuck on the update screen.
Thank you very much for your help BTW
HDD in exFAT? exFAT have serious problem and cause issues like this exFAT is fixed in next Update.
Thank you Sam, do you know when the new update will go live? Also does the box autoupdate on startup (sorry noob question)?
Well that's a relief, so is it showing no signal now or all ok?
Totally agree don't allow apps to auto start as there seems to be some odd behaviour when doing so.
Regarding the standby issue, i mentioned in a previous post on this thread, when it happens i find pressing the power button 2/3 times on remote brings it back to life and boots up normally then so try that in future. As this issue continues with multiple users i would imagine this will be escalated as a potential bug for further investigation.
in regards to the file system if you format for example a usb flash drive/hdd using exFAT as the filesystem then plug it into your box it will cause a IPTVLauncher has crashed, this happens in a continuous loop, so to solve you remove usb flash drive then reboot. This is fixed in next firmware release but in the meantime use FAT32 or NTFS, i do not recommend trying either as well it's a bug.
From what i understand, when you have hdd plugged in and boot device it gets stuck on checking for updates? but when you unplug hdd it boots up fine? If the file system on the HDD is exFAT then that will be your issue. So you will need to either format HDD to FAT32 or NTFS (i prefer NTFS myself on HDDs) and FAT32 on microsd or keep it unplugged until the new firmware release becomes available.
If getting stuck on checking for updates continues although i bet it's because you are using exFAT, although after the issues you have had i would just unplug everything at this point except the power cable, reboot device then go to settings -> system -> factory reset and start from fresh.
@droidbug all good now, as I said I managed to quickly disable the VPN using the mirror and then factory reset from the settings menu. Everything as good as new.
I noticed the problems with the HDD so I always removed it when booting, I think I will keep unplugged until the next update now .
I hope that by disabling all autostart apps will resolve the standby issue, otherwise I will have the box turn OFF rather than on Standby when using the STB button on the remote.
Excellent
If you have lots of stuff on the HDD and no way of backing it up elsewhere then yes would be easier to wait for next firmware release, if not much on there and you can back it up then you could just format it using FAT32 or NTFS then add backed up stuff back, your choice.
I do not have apps auto start and it still happens. I hold down power button and choose power off but still seems to happen.
I find if i press power button to bootup device and it does nothing, if i press power button again 2/3 times it seems to work for me.
sounds like is impossible to escape... That is really bad. I started to regret buying this box, it's one problem after another. Such a shame I had high hopes.
Have you tried other android boxes? I am not affiliated or paid in anyway but i can genuinely and honestly say the Formuler Z7+ is by far the least problematic box i have purchased.
My last box required installing unofficial custom firmware from a community forum with no audits, patches, addons just to get the basics working and then still riddled with bugs and a support team that was in denial and blamed the customer, manufacturer did not care hence the unofficial community custom firmware and the support was from the distributor, manufacturer did not want to know or supported there users and i paid double the price of the Formuler Z7+ and that's before even going into when using kodi how i had to install wrappers and addons just to play a basic video and that came with green/pink video being displayed, when it did play a video fine it stuttered, freezed and crashed regularly. Honestly it was a nightmare.
Bugs unfortunately will always exist it's just one of those things and it will not be any different with other boxes, in my case it was muchworse, formuler are always doing there best and new firmware updates are being released regularly when beta testing is complete.
This box is still new and like anything new firmware takes time to mature. I understand how frustrating it can be but from my experience the firmware on the formuler box is much more mature and stable than i have seen on other boxes that have been released 1/2+ years ago.
Same thing happened again this morning. All apps were shut down before switching unit to standby.
Will try your recommendations droidbug before trying sams. Thanks.
Will get back to you on this.
100% with you. Bought this box for my mom to make it easier for her, has ended up being a bigger pain than a cheap eBay Android box she had previously. For the premium you pay compared to those eBay boxes, you'd think it'd actually work.
I have not used other boxes, but for £100 I expect more and rightly so. I used Kodi for almost 3 years running on a rasperrypi and never had this type of problem.
I also have the standby issiue!
When i found this thred i try to disconnect my usb key memory (fat32) and disabled automstic start of the my tv online app, and when i stated the box today it starts up all fine! Rally Fast boot time!
Just for testing now i have added my tv online app to start up again! But not connected the usb key memory yet!
Thanks! For the help and the info! I was Almost throw the box out of the window yesterday!
Im relly happy thats you guys try to fix this issiue! Its more importent then the slow epg!
Thanks!
// Karl
Display MoreI also have the standby issiue!
Im relly happy thats you guys try to fix this issiue! Its more importent then the slow epg!Thanks!
// Karl
Hi Karl,
The standby issue appears to be fixed going by latest information from the Beta
All information in regards to the firmware release can be seen here: March/April Update
Thanks droidbug!
Thanks droidbug!
no problem, your very welcome
Formuler support team
please make it possible to Power On/off and wake up/standby Z7+ Using usb remote that are widely available in market. BuzzTV box already does this.
Like already written, fixed with coming update!
Today I couldn't turn on my box from standby and I had the latest update.
me too just have the latest firmware but cant turn on the box after standby. the light is green/red.
need to unplug the power cable and turn on again.
Updated firmware, still unable to wake from sleep.
It usually doesn't wake when it's in standby for a long period of time (overnight), but today I put the box to sleep for just an hour and it wouldn't turn on either.
Apparently the new update didn't fix the "wake from sleep" problem.
Sure everyone also did factory reset after this big (major) update?
I can confirm. It was stuck in standby, light was red.
Please provide the following info:
Device Model Name
System Firmware Version#
MYTVOnline Version#
System Power Mode
The last app running on-screen before putting device into standby
Device Model Name: Formuler Z7+
System Firmware Version#: v1.2.28-r14371
MYTVOnline Version#: v1.09.24-r1628
System Power Mode: Standby
The last app running on-screen before putting device into standby: MYTVOnline
It happened to me again this morning please fix it.
Thanks for the additional and detailed feedback.
Engineers will look into this issue again.
you can fix this problem by change the power mode
Go to
- settings
- then go to system
- then switch power mode from stand by to boot down
so the box boots down if you click one short time the STB Button, this works fine to me
all thru...in my experience it´s not the best way to put an iptv box in stand by mode, often times the network device didnt wake up seriously
It takes to much time for the box to boot up if you change from STANDBY to TURN OFF. It is so much more faster to turn it on from STANDBY. In my opinion the box should be TURN OFF for example if you are not going to use the box for a couple of days, especially when you are going now on a summer vacation The box is set on default on STANDBY by the FORMULER TEAM so there must be a reason why they made it that way. If they suggest that we change it from STANDBY to TURN OFF I will happily do so
It takes to much time for the box to boot up if you change from STANDBY to TURN OFF. It is so much more faster to turn it on from STANDBY. In my opinion the box should be TURN OFF for example if you are not going to use the box for a couple of days, especially when you are going now on a summer vacation The box is set on default on STANDBY by the FORMULER TEAM so there must a reason why they made it that way. If they suggest that we change it from STANDBY to TURN OFF I will happily do so
- then pull off your Power Cable 2 Times a Day until it´s fixed with the next Update,... you´re right, that´s the better way
Quote- then pull off your Power Cable 2 Times a Day until it´s fixed with the next Update,... you´re right, that´s the better way
haha! No. There is no need for that, it doesn't happen that often. It is actually working for me now because I did a factory reset after the big major update and to be honest it has woken-up from standby every single time since then. So we will see, it is working for now
I wonder if it was just that one time it didn't wake from standby, because it seems to be waking just fine now *crosses fingers* Even waking when there's a scheduled recording, and not laggy either.
I'm very impressed by the developers listening to its users, I was quite upset when I bought the box and having things not work, actually considered selling the box and getting a BuzzTV, but not anymore. Probably gonna buy another one now
I had this problem during the last update. Unplug the box for 10 seconds, plug it back in and the box will wake up and start loading the update.
Just bought this device and received updates and now wont wake up. Light stays red all the time. Do I return it since there is no reset button on the device? i unplugged and no use
I have the same problem, my Z7+ does not turn on in the morning unless you disconnect the power cable and put it back. I have read that the solution is to reset the box to factory default, I have done it two times but no success.
An update is being launched next week and hopefully it will be fixed.
Very simple question.
When in standby mode the light on the unit should be red or green .
I have the same problem. When in red, my unit will not wake up in the morning, until I unplug and replug the Z7+
Should I leave the unit GREEN all the time .
Thank you.
MY device worked perfect until I did a firmware upgrade and now its a brick, could be a bad device or something else. I ordered a second one and see if that will work.
We understand if you not happy with the box, therefore you return your`s but please stop to spam multiple threads with same text!
