Please module NTV CI+ name.
Ci+ Smit 1.3/1.2 or Neotion 1.3?
Aktuelle F3 Bug - Meldung / Current F3 Bug -Report
- F3
- SAM
- Closed
SAM Hi...
CAM- Module NTV PLUS SMIT VERSION 1.2 CI +
but the problem still exists , Satellite Express AMU1 , EUTELSAT 36A / B, 36 °
Information channel
12265L, sr: 27500 , fec: 3/4
and
Express AT1 , 56 ° .... -
Doe i understand right.. The same Modul shows on one stb 1.2 Firmware revision and on other 1.0, is that right?
SAM
it turns out that the modules CI + Software Version v1.2 and v1.3 work and CI + Software Version v1.0 does not work .... -
Only for protocol again, you agree if we say: The Modul and Card works with CI+ Firmware 1.2 and 1.3 and only with 1.0 not..? This is what i would report.
Ok i will forward this issue like shown. By the way, is not possible for you to upgrade your CI+ from 1.0 to higher working ver. 1.2 or 1.3?
SAM
I myself can not update it , you need to wait when it will make sa provider of satellite and when no one knows ... -
Marchella , i see you have also vu+ duo2, can you please put the module inside and make also the same photos? Does the Module work fine on VU+ duo?
SAM
so that time and again that this module does not work on the same Enigma ...
Don`t understand what you try to say, please doe me favour and write in Russian language, Sokar can translate later.
Install commoninterfaceassignment plugin and put the needed channels inside, reboot and test until this works. Today i tested F3 with CI+ and 1.0 software, almoste same module like yours and it didnt work at the beginning, after installing commoninterfaceassignment and add of all needed channels, it was working perfectly. Please test and report again. Thanks.
SAM
Please,please,please send this request for apply patch
https://github.com/formuler/me…e0aadd6a3cdad6d89521aa760
or
https://github.com/formuler/meta-formuler/pull/8
this is same + formuler4Enable CONFIG_MTD_NAND_NANDSIM as module in order to use with
OpenMultiboot.
It is very easy and we ask it for two years, it's just a lack of respect to all. -
Sorry to say, but there will be no support for enable of this future.
I get answers like follow:1. GENIATECH MyGica USB TV Stick T230 / T220A DVB-T2 Tuner fail.
- It's only available on the CPU has 3000 DMIPS above & V4.5 kernel. It's not able to support for F3 further.2. Enable from nandsim module - Git Hub
- NANDSIM use more cash memory. We don't have plan to support this.Other Issues will be checked.
Code
2. Enable from nandsim module - Git Hub - NANDSIM use more cash memory. We don't have plan to support this.
I do not understand, this is a joke?
NANDSIM is used for unpacking image.
This is done once and for all.
See OE https://github.com/oe-alliance…&q=NANDSIM&utf8=%E2%9C%93
All box use it.E.g.
https://github.com/oe-alliance…/formuler1/defconfig#L966 -
Delation vfdcontrol from meta-formuler - Git - Hub - removed
Again...
On openPli can now be used OpenMultiboot
https://github.com/OpenPLi/ope…8e59502320cffaf41f511e254For oe-alliance images nandsim use for all box/model
Please ask for more time to enable configuration NANDSIM for F1/3/4
No memory problems should not be.
E.G. openATV use it. No problem.This module not enabled only openPLi.This is nonsense, please understand me correctly.
Dimitrij i understand very well what you say, but this is not my decision! The Techniq say no support for this issue and after third Email about this issue no reaction, what should i do now?
If you know someone from PLI developer team, speak with him and he should try to convince the Formuler Techniq to set nandsim. -
All OK.
OpenPli open your repository for formuler.
