Good day to all! The problem with the receiver Formuler F3, it does not support the display of signal strength in the AGC. Image of Open PLI last.
The same problem was with the receivers Xtrend ET-9200 and was solved by improvements drivers. Will there be a solution for Formuler F3 ???
AGC level
- F3
- Openboxfan
- Closed
Hello openboxfan,
Thank you for this Information. This Bug will be forwarded to Formuler Team. I let you know when we get answer or bugfix.
Asked colleagues on this issue. On the receiver Vu+Zero such issue no.
Yes we know, its Bug and is already forwarded to Formuler Team, they work on this issue.
Hi SAM!
Is there any progress in correcting the driver to display the signal strength AGC? It's been almost 2 months - it is more than sufficient time even to correct kernel !!
Yes indeed, i will send tonight new Email and ask when this Bug will be fixed.
ok, thanks!!
Two and a half months to solve the problem, which is only an extra tick when compiling the driver - it's probably over a difficult task for programmers !!! I'm shocked !!
I understand your frustration and spoke with Formuler about this issue. Formuler Team continuously make complaint to the driver - developing team about this Bug and will make more presser to be fixed. Sometime have D-teams they own priority list Sorry but at moment i don`t have better news for you and hope the fix will come asap.
Formuler Team is dead. I'm sorry to admit it
Maybe other fixes have got a higher priority.
Yes, it should have been solved already. I hope also that they will fix it.
But there are other things, which have to be fixed, which are more important for me. That's what I'm wanted to say. Sorry, if you maybe understood it wrong
It's time to fix it. And then the users brain endure.
Пора бы исправить. А то пользователи мозг выносят.
With driver update from today, is AGC Signal fixed and they made optimization on Tuner-Signal also. Image Teams will implement this ASAP.
Well, thank God, finally !!! Thank you for this course ...
Good thinks need time, your welcome
Funktioniert nicht BER
