SVC_171119.asvc
Settings
- Miscellaneous
- S-Turbo
- enzover
- Closed
Hi halil52
Wtah is the error??
Hi Robert,
No matter what I change as ending I have Cheksum mistake
You need to do the file "import file" and not "open file" .. modify the channels and then do "export file"
Thanks Robert.
Now I got it. Effortless, but it works -
Quote
when and where appears it to you "indices not included in the range"??
If you backup the normal channel list from Formuler, rename from .nsvc to .asvc and import with [lexicon]editor[/lexicon], then comes x11 the message (in my case 19.2-13°). After confirm each time with Ok, the [lexicon]Editor[/lexicon] loads the list without problems and you can edit.
try not renaming the file leaving it nsvc...
Hi Everyone,
From today i will be working on channel listings for 28.2e as i'm more familiar with the channels from the UK.
I should have the completed version very soon and I will upload this perhaps to a new thread ready for download. I may make mistakes along the way or need help on how to get going but i'll get this done.OpenPro
Hello friends,
I have also finished getting [lexicon]settings[/lexicon]. Astral 19.2 + Hotbird13.0 + Turksat42.5 and Eutelsat 7.0 °.
This is an export file. Asvc.
Man can import [lexicon]settings[/lexicon] instantly with USB stick to Formuler STURBO or Formuler mini -
Same Message. How ever, its not big deal after 11x Ok you can edit and export. File will be accepted from Formuler Box, would be only nice to find some solution if possible and to know why this happens.
I have open new thread for Channel Lists/[lexicon]Settings[/lexicon] upload. Please upload all your Channel lists again and in future only there >> User Channel Lists/Settings
Thank you for your effort. -
Hey Guys,
I can seem to transfer the channel list to CTE (Clarke Tech [lexicon]Editor[/lexicon])what am i doing wrong?
- I generated the file on S Turbo and uploaded the file to USB
- Transferred the file from USB to Windows 10 Desktop
- Renamed file to from NSVC to ASVC.
- Opened CTE and clicked IMPORT. error comes up please see attachment.
- Tried both NSVC to ASVC files
Any ideas please?
Hi all,
its okay i got it working
Hi Everyone,
Did you happen to get around to getting a list done for 28.2. Ive started to make one manually using the formuler, but i cant figure out how to actually move channels within a favourite category. When I select move, it moves the channels into a different box on the screen, but when i then try and move them to a different location in the favourite, they just go back to the same location they were in originally. -
Ive attempted to make a FTA channel list for 28.2 If someone could try it out for me and give me some feedback, that would be much appreciated
