I have found that my Amazon Prime is crashing when starting playback. Is this an issue I can resolve by changing some [lexicon]settings[/lexicon]?
Amazon Prime issues
- Miscellaneous
- Z7+
- Steveoo
- Closed
I think the best way is a reset hardware.. for me it's work I had the same problem with Netflix
Hallo zusammen,
ich habe das gleiche Problem, sobald ein Film gestartet wird, läuft er an und die App Amazon Prime Video wird beendet.
Habe schon auf Werkseinstellung zurück gesetzt, aber das Problem bleibt.
Hat jemand eine Lösung ?Hello together,
I have the same problem, as soon as a movie is started, it starts up and the Amazon Prime Video app stops.
I have already reset to factory [lexicon]settings[/lexicon], but the problem remains.
Anybody got a solution?Gruß
Oliver -
Yes. If someone has an answer to this, that would be great.
I encountered this yesterday as well and have tried everything I could think of to fix it to no avail.TIA
Download this two Apps and copy to usb stick, then install on Z7+.
URL-> https://mega.nz/#!klgCRSxY!4gw…WB6oWLoPiJh6GX1feXvHxx984 -
Thank you.
I will try this later this evening.
<p>@Sam</p>
<p>Thank you, Amazon Prime works fine.</p>
<p>Can you help here too, the sky go app dont start. I klick on the app, but the app not start.</p>
Same here with Sky Go
Sky go uk will not work with hdmi devices
But it works (the german version) with the aftv stick......
So, it should work with z7+ (?) -
URL-> https://mega.nz/#!klgCRSxY!4gw…WB6oWLoPiJh6GX1feXvHxx984I know I’m a little old coming to this party but has anybody got the 2 apps there were here still available. I would like to get amazon prime to work on my z7+ box.
Thank you.
Amazon changed something. After install of this two older apps you must update immediately and this leads to not working app.
has a fix been found yet?
Yep down load kodi beta 2 Leia, and the Amazon vod Addon, enter details and everything should work. You will on get SD feeds as Formular choose not to add Widevine LVL 1 to there boxes. This could still be done but would involve return the boxes back to them for a fee.
Please note, it was not the decision from them, they didn`t get official license for Netflix and LVL1. Amazon cuts now also where they can and want to push they own boxes.
Hallo zusammen,
der Link funktioniert nicht mehr (https://mega.nz/#!klgCRSxY!4gw…WB6oWLoPiJh6GX1feXvHxx984),
hätte jemand die Programme für mich da ich das gleiche Problem habe.
Danke
Hello, I've tried several times to download and then open the above .rar file and I get an error. Has anyone had success opening and installing Amazon Prime Video 3.0.236.46641?
I just downloaded it right now on my laptop without any issues.
how did you get it onto your formuler?
