Extra space
  • Hi All,
    I have a Formuler Z android box and I wanted to expand the space available so I can stream movies and shows from PopcornTime, first I've tested with an sd-card type 10 and after changing the default storage to the card, most of the times PopcornTime crashes.
    Now I'm testing using a usb pen and changed the default storage there, PopcornTime launches perfectly but the streaming does not work properly. If I download instead it works but it is really slowly, speed for download increases but after a while it goes to 0.
    I tried with no sd-card or pen and it works perfectly.
    Can anyone know what I'm doing wrong or if it had similar issue?
    Thanks.
