S-Turbo 1gb ram
  • Hi , am about to purchase a Formuler box , I have had numerous boxes over the years including both cheap chinese rubbish and high end boxes. I looked straight at the F1 because it has 2gb ram , I currently have a 3gb BB2 box that still is slow when scrolling through EPG's or when loading metadata when scrolling through movie lists in kodi. But I want the option on watching a channel whilst recording others so for that I need the S-Turbo or mini ( I can't see much difference between the two other than the usb3 port on the S-Turbo) , so I have to say I am a bit apprehensive about the 1gb of ram's ability to handle what i have posted above ? Is there another model option for my specs ? I want android .
  • The Formuler F1 is a Linux E2 box and has 1Gb ram
    Technische Daten:
    1300 MHz BCM Dual Core Prozessor
    1GB DDR3 DRAM
    512MB Flash
    Gigabit LAN
    2xDVB-S2, 3rd Tuner optional
    2 x SmartCard-Reader
    1 x CI Slot
    3 x USB Ports
    1 x SD Memory Card-Slot
    e-SATA HDD Port
    SPDIF Dolby optisch
    HDMI 1.4
    VFD Display 8 stellig
    HD PIP (Bild in Bild)
    HBBTV Support
    Viele Grüße / Best regards
    anmado :)
