HDR ativates with HD streams
  • Hello,
    This is a known issue and will be patched in the March firmware update.
    Issue:
    Android [lexicon]Settings[/lexicon] >> Advanced Options >> TV HDR Mode >> Auto
    When TV HDR Mode is set to Auto, and incoming video stream is SDR, HDR mode is activated anyways and the colors displayed on the TV are not correct.
    Resolution:
    When TV HDR Mode is set to Auto, HDR mode will only be activated when incoming contents are HDR.
    In the meantime you can set or deactivate HDR manually:
    Android [lexicon]Settings[/lexicon] >> Advanced Options >> TV HDR Mode >> Set to SDR to turn off HDR
