rebooting box
  • Hello
    i own a z7+ what is the recommended way to reboot the box? I have been going into the setting menu and changing the power key function from standby to power off to preform a quick power cycle. I notice there is a software reset but im scared that will delete my portal info in mytv online?
    Also is it normal that iptv launcher crashes non stop until i unplug my usb key? As soon as I do it boots no problem and i plug back in my key. Trying to learn the ins and outs of the box.
    I am on mytv app version 1.09.06-r1443
    and the box is on s/w version 1.2.16
    build date 1-24-2018
    Thanks for any help
    Einmal editiert, zuletzt von r0ll ()
  • Launcher crashing issue has been solved and the patch will be released later this month.
    The crashing issue occurs with exFAT formatted media (USB stick or microSD)
