Pause, rewind live tv
  • Hi,
    Question for you...
    Should I be able to pause and rewind live channels? I thought I could but it’s not working today. Is there something to setup?
    I have a 300GB drive installed on the USB port.
    thanks,
  • Hi, please make sure the output resolution is set to 1080p on your Z7+
    Press the RESOLUTION button on the RCU and select 1080p.
    Restart MOL and try again.
  • Hi,
    Formuler is aware of the issue and It is something we're looking into.
    The issue stems from a limitation at the kernel level (demux) and we're working with the SoC provider to try and find a solution.
