  • Do I need to purchase an external storage flash or mini sd in order for this function to work on a z7?
    When i activate the "play" button as directed on a stream in myonlinetv app, nothing happens. By that i mean the timeshift buttons do not come up.
  • Insert external USB flash drive or microSD card to use Timeshift and Recording with MYTVOnline
  • I am having the same problem. It was working fine . I have used a USB memory stick and an SD card but it has stopped working. On a tutorial I viewed it said it will record until the memory is full. I thought that might be the problem so I´ve tried formating the Sd Card and the USB stick (FAT32) but it still isn´t working. Can you delete files from the internal storage and if so how? Is there a somewhere in settings where you can access "timeshift"?
