Hello.
Has anyone else experienced bad performance when using Smart IPTV app?
I have uploaded the M3U to the siptv.eu site in the correct format, and whatever i try, most channels are freezing, even the SD ones.
I have changed the buffer on the app to maximum and connected direct by lan to the router and still the same.
Using MyTVOnline I get perfect results! and the same M3U on a different android box works fine.
Is there a firmware issue that needs to be addressed? is anyone else experiencing the same difficulties?
