My Formuler Z7+ turn into "sleep" mode with red ligth flash
  • Hello,
    i have a problem with my formuler it turns off about 5 minutes to sleep mode with the red ligth flashing.
    i try with different resolutions in 2 different tv's,i verify the sleep mode in mytvonline, i try without sdcard, software reset and
    i still have the same problem.
    I never see the Fomuler z7+ with this "RED LIGHT Flashing" anyone can help me?
  • Hi,
    At this point can you try a factory reset? you mention you did a software reset but not a factory reset. Not sure if the red flashing led is an indication of a specific problem, hopefully someone from Formuler can reply but try a factory reset and reply back with outcome.
    Please remove any devices you may have connected to the Formuler box like usb flash drive before doing a factory reset. Also please note exFAT, currently there is a bug that causes the formuler device to crash so please make sure you use FAT32 or NTFS, the exFAT bug is already fixed in next firmware release.
    Thank you.
  • Can you post a video of the issue?
