wifi issues
  • hi ... newbie here...can any one help me with this? Do i need to use the wifi usb antenna for me to be able see my wifi netwoks?
  • I can not get 5ghz in my New z7+.
    I have Wifi with 2,4 and 5 ghz but only 2,4 dissepear in my Formuler.I have nividia shield too and no problem with 5 ghz.
    What can i do?
    What can i do?
    Hopefully you've been able to figure it out.
    If not try this:
    Check your router settings for your 5Ghz band and see if it's set to "auto".
    Manually set the Wireless channel to 149 and see if that works.
