this box has issue after issue. Here is a new one...it wont power on.
Model: z7+
Retail Box
Firmware version and date: the most current one..cant tell you because it wont power on
MyTVOnline version and date: same as above
Did you factory reset your device? and when? N/A
What issue(s) are you having? when i hit the power on button on remote, the unit does not turn on. The red light does not change to green. I have changed batteries in the remote.
What was you expecting to happen? the unit to turn on!
What happened instead? the unit does not power on
