No Internet
  • Hi All,
    I just got my Z7+ and fired it up. First tried Wired connection, it found the IP, Gateway etc but says INTERNET CONNECTION : NO. So I proceeded to disable Wired and try WIFI, same say connected with 72Mbps link but Internet was still no. I have a Mag device as well, that instantly connected to the net no issues.
    I then took my device to my home theater where I know all Intenret connections work. Still same issue. I also factory reset and tried and still the same.
    Do I have a faulty unit?? Is there anything else I could try?
