I Only Get Channels 1-89
  • I am unable to get channels above 89. If I type 348 on the remote, it tunes to channel 34. I am unable to tune 3 digit and 4 digit channels. The EPG only shows channels 1-89, then back to 1 again.
    I have the latest update for the Formuler Z7+.
  • Unable to reproduce the issue.
    Make sure you're currently not in a channel sub-group and try again.
    In other words, press the GROUP button on the RCU, select the "ALL" group and try again.
    If this doesn't work, it is a provider issue.
    Contact your service provider for more help.
