Z7+ stuck in version 1.2.10 r12567
  • Hello,
    I received my Z7+ today. It's at version 1.2.10 r12567.
    I booted for the first time. I got to the main menu.
    I restarted the system but it got stuck in a boot loop.
    I tried the recovery procedure.
    Finally I'm able to get it running again but the updates are never seen/downloaded nor installed.
    Is there a way to force a software upgrade else than trying to get an OTA that's not coming?
    I'm stuck in this v.1.2.10 buggy with myonlinetv buggy freezing / laggy and no epg :)
    Thank you
  • Ok Guys,
    I was able to upgrade finally. Whether I connected to my wifi or wired connection. It always reports Internet connection: no.
    I tried connecting wifi to my galaxy phone and tether the data connection. It worked - internet connection yes.
    I was offered to upgrade.
    The thing is all my devices are behind a firewall which permits ip any any from inside vit from outside, nothing passes. I don't know if there's a check coming from outside that sends an ok... to the z7+ system.
    Do we need to open any ports from outside connections for the z7+?
    It seems we do...
    I don't want to put the formuler z7+ straight on the internet - no way ! Any ideas?
    Edited once, last by taister ().
  • Ok - I found the answer.
    The Z7+ has to be pingable from the outside network in order to display : Connected to internet: yes.
    It's not a matter of being able to reach internet from inside... well.
