Few minor items that I need help on
  • Volume - some shows, commercials the volume is so low you cant hear it and others it is super loud. Is there anyway to have the sound to normalize?
    Is there a way to save recording to the device or it always has to be external USB?
    Sound - I have no surround sound coming thru my rear speakers - do I need to adjust a setting?
    subtitles? how do I turn on
    Einmal editiert, zuletzt von kingrat2017 ()
    No, this should be set on TV. Many Tv´s have setting for this.
    You mean to intern flash, NO. This is only for System, OS and Apps, for recording it`s not enough place on it. Recording always to SD Card or extern USB device.
    Depends how you set and what you use. See also the thread instructions. Check also your AVR and settings on it if you already prepare the box for DD, if rear speakers doesn`t work then it`s your chosen Surround mode on avr.
    Example: If you use " Multi Channel Stereo" then you should hear from each speaker sound, if you chose only Stereo then you hear only from front speakers something.
    Red Button -> Subtitles
