Epg program info
  • Hi, I'm using m3u portal and epg and it's working fine. The only thing that is not working is the program description. Nothing shows while on other apps using the same epg url it works. Is there a fix for this please?
  • Hi there.
    I am also having the same issue...input the M3U path and the XML path.
    Channels all appear and playback is v good..but EPG shows no info.
    Same if I browse to the M3U file or input it as a URL....any ideas folks?
    Cheers.
    I have the same issue. Also, the epg doesn't pick up data for some channels while other m3u apps like perfect player do grab data for them. No channels have program descriptions though...
