Guide size when paused
  • When I pause live TV, and subsequently press ok button to change a channel, guide comes up small and incorrectly formatted only having enough space for two channels... when channel is changed it returns to correct size. Is there a fix for that? Thanks...
  • The issue you described in the first post should be patched late August.
