Audio Distortion on Ondemand media
  • Hi there
    Hoping you can help.
    When watching on demand media, there is a strage sound vibration or distortion every 5 mins or so. It just lasts 2 or 3 seconds but really annoying as any sound or dialogue cannot be heard.
    Happens whether I use soundbar or just tv speakers.
    Doesn't happen when I play same media on another box (e.g enigma2 box). Doesnt happen when watching live IPTV content.
    Is this a known issue ?
    Thanks!
  • This isn't a known issue.
    Unfortunately it is impossible to debug without getting the media file for testing.
    Are you saying the exact same stream source/media is being played back on your e2 box and it is ok?
    What method or protocol are you using to playback the media on the e2 box?
  • Try adjusting the Android sound output settings to make sure it matches your equipment.
    If that doesn't work, Do a factory reset and try again.
