Save/Restore Settings
  • I frequently see the answer to questions that are posted is to do a factory reset. Is there an option to save your portal login info (MAG and M3U), favorites, and regular settings where you can simply restore. I suspect the answer is no but this should exist.
  • You can also download their app from googleplay and just copy paste or just type the url from your phone. It's really smart! ;)
    p.s. Works only with Android phones
