MOL reload when VOD watching
Important:
  • intellinet
    Changed the title of the thread from “MOL reboot during VOD watching” to “MOL reload when VOD watching”.
  • Bonjour
    j ai aussi ce problème ainsi que ma famille et amis
    depuis la derniere mise a jour
    j ai fait reset toos avec fichier update ird mais toujours pareille
    merci
  • HI
    Do you why MOL on Z+ and Z7+ reload during i watch VOD. No matter last update or not. It happens many times.
    Did someone have same issue?This is an example
    Try doing a factory reset and do not install any other apps except MYTVOnline.
    Does the problem persist?
  • Same problem : MOL on LIVE or VOD watching on hight bitreate stream <10 mbps and up...
    i want this problem simulate, but its heap ens randomly :(
    Vaidas
    Vaidas
    Do you know the video codec of the high bitrate stream? Is it h.264 or h.265 (hevc?)
  • h.264 stream and vod i using didn't have h.265 to test
    little helps if delete epg data from mol , 2-3 hours
    watching different channels opening vod ... same problem happens.
  • The engineers are aware of the hanging issue and are trying to replicate it in the lab.
    Hope to release a beta test patch version soon.
  • i hope release will be soon...
    I can give real acaunt to our system for testing reasons to simulate problems, test channels, test 4k Channels, h.264 or h.265
    only for you make channel list and etc.....
    Closed the thread.
