Correct sound settings
Important:
  • Please provide the following details:
    • Your AV equipment setup in relation to your Formuler device.
    • Which version of the Z7+ do you have? Global or N.American version?
    • Connected with WiFi or Ethernet?
  • Can you check if wifi and bluetooth are turned on?
  • I would recommend doing a factory reset to see if the problem persists.
    If the problem persists after that, try a different hdmi cable and different hdmi port on your TV
