Ethernet problem
Important:
  • Hi my first post so thanks for reading
    I have a formuler z prime box it connects great with WiFi. But withEthernet it keeps loosing connection every few mins. I have re set box and router used 2 different new Ethernet cables. Took box to a friends to try there router no difference. Both routers used were VM super hub 3. Any help would be great. Thanks Daz
  • Hello,
    Welcome to the forums.
    We have been receiving sporadic reports about this issue.
    The issues is known, but the cause is not clear.
    Can you try setting a Static IP on your Formuler device to see if it helps with the connection issue?
  • Hi thanks for your reply not sure if you can set a static ip on virgin. What I did was set a reserved IP. It didn’t make any difference. One thing I have found if I watch you tube through box it’s fine so thought it may be my tv online app ? I have reset the box so presume that reinstalls app from new ? I have read maybe a problem with the super hub 3. So not sure what to do next.
    Thanks daz.
