Multiple M3U Portals?
Important:
  • Is it possible to add more than one M3U Playlist 'portal' in MYO?
    All except one of the empty Portal slots seem to be for MAC/XtreamCodes credentials. I have one M3U Playlist added and would like to add a backup second M3U from another provider in another portal.
    Can this be done?
  • Have 2 portal connections one using Mac address which is showing EPG and one using M3U detail connection, however I'm unable to view EPG can someone advise please?
  • If you do some forum searching you’ll find that there are known bugs surrounding M3U + EPG data. The hope is it’ll be fixed in September update.
    ps just to confirm, you did provide MUTVONLINE with a EPG URL along with your playlist URL right?
    Yeah entered both URL for Playlist and EPG
    Some providers don't have seperate epg.
    When i use a m3u in another addon i have epg without an extra epg line.
    Why is this not possible in the mytvonline app?
