SSD USB Thumb Drive
Important:
  • Greetings,
    I have a SSD USB Thumb Drive 256GB it’s mounted but my Formuler z7+ never asked to format the The numb drive I want to use it has my internal flash drive for my additional settings can this be done on this device I have the same configuration on my shield has mounted has and internal drive
    Regards
    Marko
  • Currently, you can't use external storage to expand the internal storage for apps and appdata.
    The engineers are working on bringing this feature to the device, but it will take some more time.
