Apps won't install/Apks3wont install
  • hi There,
    First post so if I say something I shouldn't then please accept my apologies.
    Not long had my Formuler z box, but today no apks will install and apps won't install from the market, I keep getting a message "can't parse file" and "install fail error code 2"
    Any ideas how I can sort this
    Many thanks
  • Hello,
    Please make sure you have updated to the latest firmware on your Z Prime.
    You can check for firmware updates by going to the Update App located in the Quick Settings menu:
    Home >> Settings (cog wheel icon) >> Update
    If your box is up-to-date, but you still can't install any apps, then I recommend you do a Factory Reset of your box.
    This procedure will erase all data and return the unit to factory state:
    Home >> Settings >> System >> Factory Reset
  • thanks very much. Nothing saved on it anyway apart from my mac address details for my Iptv, will affect that??
    Will try when I get home anyway!
    Thanks again
  • MAC is not affected.
    If you still have an active subscription with a portal provider, it would be wise to write down the portal URL so you can input it again after the Factory Reset procedure.
  • Hello,
    I have the same problem even with apps in the market.
    It occurs after every update.
    Furthermore, the apps already installed doesn't launch anymore.
    I updated the formuler this week and i can't launch kodi from now on.
    When i do a factory reset, it comes back to normal but if i have to do a factory reset after every update, it's not very convenient...
    Any tips?
    Thanks.
    Closed the thread.
