Formuler z7+ Remote
Important:
  • Greetings,
    I have the Formuler z7+ with the remote for STB emulator app can I purchase a second one for my shield that has STB emulator? Right now I’m using costimized kB mapping
    Regards
    Marko8)
  • Formuler Z7+ is an IR (Infrared) remote that only works on Formuler devices.
    Nvidia shield uses a Bluetooth remote. They are incompatible.
  • You can order the small Formuler remote from your dealer.
    Or you can use any Bluetooth or RF remote. Your control of the MYTVOnline app will be limited however
