Wifi Portal Login
  • Hi all.
    I have a formuler z+ and I need to connect it to an open wifi network that requires me to login by accessing a Wifi Web Portal login page.
    How can I do that? I’m able to connect to the wifi network, but I can’t find a way to access the login webpage so that I can proceed with the login.
    Thanks in advance!
  • Hello,
    Go to the Market on the homescreen and download Puffin TV Browser (web browser)
    Try to open any webpage, and you should be directed to the wifi login page.
  • What is the method you use to connect to this network with other devices like your smartphone or PC?
    This is like a typical hotel wifi network. I connect to the network and it opens up a browser with a portal asking for credentials. In the case of Z+ I connect to the network and after that I manually open a browser but it doesn’t load the portal. It opens with a blank page.
  • open google.com in the browser and it should redirect you to the hotel login page.
    Closed the thread.
