No way to change channel during EPG loading
  • Hi,
    Since v.1.9.48 I can see "EPG loading" in top right corner of the screen when starting MyTVonline.
    But unfortunately with one of my provider it takes more than 30 seconds to load EPG and during this time no way to change channel : I can select it but it won't appear until EPG update has finished.
    EDIT : SOLVED WITH BETA 1.9.49.
    Keep going your excellent update and please :
    - Add free recording based on time and not EPG (and allow to add some extra time on EPG recording)
    Added the Label Solved
    Closed the thread.
