Closed captions subtitles
  • Hello,
    I upgraded from MAG 254 device to Formuler ZX and I am happy about it, but since I have my sister hear-impaired I need english subtitles. My provider has every channel with closed caption subtitles (not teletext ones or dvb as I understand) and they worked flawlessly when I used MAG 254 device. Now I started using my brand new Formuler and when I select subtitles pressing red button on RC it does show None. I add media codec settings which stream uses as a screenshot.
    How can I fix this problem, it is really necessary for my sister?
    Thank you!
  • Test this again after coming official firmware, there was some changes made in subtitles.
    • Teletext Subtitles supported
    • Remember last selected subtitle preference per channel
    • FIX: Black subtitle font when only 1 subtitle track is available
  • Hi,
    Thanks for bringing this issue up.
    Can you copy and paste the entire text of the codec tab from VLC?
    You can remove any link information before posting.
  • any news? my formuler updated but mytvonline still doesnt show closed caption subtitles.
    PM me if you can record some contents that contain the closed captions so it can be forwarded to the developers for analysis.
