SPDIF failure?
Important:
  • does any one have an issue with the spdif that has suddenly stopped working?
    No sound on any portal and channel. All worked flawless, sound works on HDMI.
  • 1 settings in android-->sound
    Hdmi=auto
    Spdif=raw (or pcm if there no sound)
    And third option you can try auto, 5.1 or 7.1.
    Try it all 👍🏻
    2 did you download the "audio optimizer" app from the formuler market/appstore?
    If not, download it en start it.
    No sound at all?
    Check your spdif cable
    Change the ends of the cable. The End thats in the formuler goes in receiver and the end of cable whats in the receiver goes to the formuler. (Strange,but it was a solution by me)
    Or factory reset your box (not software reset but factory reset!)
    Then check android --> sound again for the settings.
    Closed the thread.
