EPG synchronization
  • Hi!
    I've been using my Formuler 7+ these last few days.
    One of the difficulties has to do with synchronizing the EPG info, with the real time.
    As far as i can see, i can achieve that if i choose UTC, but such option does not exist.
    Righ now, in Europe we are still in summer "time" and if i choose as Region and Area, Europe and London, the EPG gets offset by one hour.
    So to get things right i had to choose as Region and Area, Atlantic and Azores.
    In a month last Sunday of October we will be using winter time".
    Then, probably i will have to change the Region and Area to Europe and London.
    Wouldn't it be simpler if a simple UTC option, without summer and winter times existed ?
    Or keeping the actual scheme, where the local time is right on the screen, but providing a field to declare a offset like -3, -2, -1, 0, +1, +2, +3 hours, to be applied and sent to the apps ?
    Regards. :)
  • Manual EPG offset in MYTVOnline will be available in the upcoming software update.
  • Hi my epg work when i Click on ok Button but when i Click epg i have no possibility to back in Time to watch tv or record . The epg write no information but when i Click ok i have epg informations do you help me ... Thank you
    Closed the thread.
