Recording only 1h even though having 1TB external USB
Important:
  • Hi!
    So when I want to record and press the red recording button the time that shows the recording time is limited to 1hour?? So I tried with a 32GB USB and nothing changed, and then I got a External USB Harddrive from Toshiba with 1TB. Still the same problem. My playlist is empty and the harddrive too. Please can you help me!!:(
  • Hi!
    When you press the record button without any EPG active, or with a program already started, you get the default 1 hour record time.
    Press again the record button and change the end time as desired.
    Regards.
  • Hi,
    When i click again on the button REC, the logo REC disappears. I don't have a window to adjust the hours.
    It's not when i record a program i'm seeing at he moment but when i program a record later in the day.
    Another question: the playlist shows the records already made but can i see the records i've programmed (i.e not already done)?
    Z8 (Mac adress)
    Edited once, last by hdr ().
  • You the window to extend a recording is only available when a recording is actively occurring, I believe.
    As for seeing what programs you’ve made in advance, I don’t think there’s a specific window for that.
  • A show planned in future.
    It's weird, i recorded 2 programs yesterday and one perfectly worked (1h39 mn) and not the other (stopped at 1h).
    Z8 (Mac adress)
  • For the issue of extending time for a recording in the future, that feature does not (yet) exist. As for a recording failing to go the full time, there are a ton of reasons why this could happen, mainly due to the stream itself. And btw, recordings stopping early is a common occurrence. Don’t rely on recordings to work 100% of the time
    Closed the thread.
    Removed the Label wcf.acp.label.label6
