MyTvOnline needs MAC adress registered
Important:
  • Hello!
    I start my journey in this forum, to find answer to failed connection in my URL list, using MyTvOnline.
    In another device, with S**** IPTV app, I had to upload the list and regist the MAC adress.
    My question is if I need to regist, the MAC adress "from" MyTvOnline to get the connection.
    Thank you.
    Formuler Z7+
  • Hello!
    Thank you.
    Mytvonline is better than smartiptv.
    I suggest to use mytvonline.
    You can use macadres or m3u link with mytvonline 😀
    Closed the thread.
