No sound
  • Hope someone can help. Got a cinema room using a projector linked via hdmi to my formuler z7 I have 2 LG Soundbars connected via optical Both work individually but when I use optical splitter there is no sound. Any suggestions. What settings do I have to use. Got 3 splitters none work.
  • You may need an active/amplified splitter for it to work.
    The signal may become too attenuated if using a passive splitter.
    Try finding an amplified splitter that uses USB power so you can tap one of the usb ports on your device for power.
  • When I connect 1 soundbar to splitter it works but the other doesn’t. However when u connect both individually to box they both work.
    Closed the thread.
