Recording issue.
  • Trying to record two shows one is 09:00-10:05 and the other is 10:00-11:05.
    I have a five minutes conflicts. How can I change the duration of recording before the recording starts. Is this possible ?
  • Will you be home at this time? Or you want to setup recordings in advance ? If you’re home it can be done (but you’ll miss 5mins of one of the shows). If you’re doing it in advance, not sure. Trial an error is my suggestion!
  • I’ll be away. :( can’t seem to find any info about changing the start and end time.
    That would be a nice feature since a lot of tv shows now add the extra five minutes to show what happened in the previous episode.
  • The devs I believe are working updating this feature so that you can manually set start and end time.
    Right now, if you’re watching a channel, press record and then record again. A menu will pop up, and then press the ‘right arrow’. Doing this will add time to the recording.
    Thanks! hope so!!
    I know about pressing record twice for the duration recording but I won't be here and will miss recording one show :(
    Closed the thread.
