PVR Recording
  • OK I am trying recording some shows and it seems to work so far shows are being recorded and I can play them back. I have 2 questions for the group what is the maximum usb thumb drive size is 128 gig ok can I use one that size? and secondly if I record shows a week in advance will they record while in sleep mode?
    Any other info would be appreciated greatly thanks:)
  • 1. For SD Cards: 256GB (Gigabytes) is the maximum supported size on Formuler Android-based products. USB Sticks and HDD's of course much more.
    2. Yes, it should record even in sleep mode.
    Ragu, What app do you use for recording? MTVO or something like IPTV Extreme Pro?
    thanks
    Closed the thread.
