The S-mini does not light the way it has on the device
  • Hello I have this problem Formuler s-mini after switching on does not illuminate at all the green display and after switching off it is not as the photo is orange green. But after switching off only red light and I have in the menu set to run the device immediately, I do not know if there is a problem with the firmware or the device. And when I turn on the driver to turn it on sometimes it does not respond and I have to turn off the device from the socket and it also happens to be another problem that the TV will turn on after turning on itself and the device itself turns off and I have to turn it on again but then I will not turn myself off thanks in advance for the answer. Altarus
