Mcas app
  • Hallo, in the list of addon Mcas app does not exist anymore? I remove from formuler 4s to try reinstall it becouse it not work with new software version.
    Where I can found the app?
    Thank!
    Rob
  • Download and install XCam3 from the plugin menu.
    Smartcard is controlled from XCam3 now.
  • I've tried to install Xcam3, but the smartcard don't work. The card is a Nagravision Italian TvSat and with Mcas app worked fine (directly in the formuler cas slot, not through CI).
  • Unzip the attached file and use your PC (SMB) to copy the file to
    \\STB_IP\share\plugin\oscam\
    Then try again please
    Files
    • oscam.zip
      (284 Byte, downloaded 33 times, last: )
  • Hallo,
    I try to copy the file in the directory, but nothing has changed (both Xcam3 app started or stopped). The smartcard not work and the tvsat channels are not visible.
    If your card is not listed here, it probably won't work.
    http://www.streamboard.tv/oscam/wiki/CardsList#Nagra
    Does the card work in other devices like E2?
  • If your card is not listed here, it probably won't work.
    The card is listed in the website, as showed below.
    The card work well with Mcas app and It has not worked anymore since I updated new formuler firmware (I do not understand "like E2" , perhaps Enigma 2?)
    An other question ... I can use a backup (sys/data) to restore the old firmware? It's possible downgrade to re-use old configuration with Mcas?
    Thanks for your kind support.
    Tivusat (IT) (183D/Sat)
    • ATR: 3F FF 95 00 FF 91 81 71 FF 47 00 54 49 47 45 52 30 30 33 20 52 65 76 32 35 30 64
    • CAID: 183D
    • Providers: 5411
    • id:
    • ECM: ok
    • EMM: ok (DVB-API, mgcamd1.35a on newcamd protocol, CCcam as client on newcamd)
    Tivusat (IT) (183E/Sat)
    • ATR: 3F FF 95 00 FF 91 81 71 FE 47 00 54 49 47 45 52 36 30 31 20 52 65 76 4D 38 37 14
    • CAID: 183E
    • Providers: 5411
    • id: TIGER601 RevM87
    • ECM: ok
    • EMM: ok
  • FIRMWARE ROLLBACK FOR FORMULER S TURBO
    DOWNLOAD ONE OF THE FOLLOWING FIRMWARE FOR FORMULER S TURBO
    https://yadi.sk/d/W97ECGyz3YcdkM
    FAC.Formuler-R.S-Turbo.PATCH.v1.6.11-r15210.ird
    30 Jun 2018, 10:56
    https://yadi.sk/d/cCAMmKbRh06AzA
    FAC.Formuler-R.S-Turbo.PATCH.v1.6.23-r16560.zip
    07 Nov 2018, 12:00
    TEST Firmware Version 1.6.23
    THESE FIRMWARE ARE BEFORE VERSION 1.6.26 (THAT DON'T ALLOW THE USE OF MCAS)
    To restore your console, you must:
    1. Download the file with the firmware.
    2. Rename file to update.ird
    3. Copy it to the root on a USB flash drive.
    4. Connect the USB flash drive to the console and at the time of inclusion in the network, repeatedly press "CH Up (up)" on the remote control before starting the software update process.
    5. After recovery, the decoder will reboot and exit to normal operation
    and then install channel list and mcas
    disconnect your decoder from lan connection to avoid firmware upgrade that don't allow mcas plugin
