Problems with analog audio out
  • Since the update, the analog audio output does not work after using YouTube.
    Only a factory reset helps.
    The right output cracks very loud.
    Greetings Stefan
  • You are using the 3.5mm to 3-RCA composite A/V cable?
    After factory reset, the analog sound is working, but after using Youtube, the sound stops working?
    After the sound stops working, the Right analog audio output starts crackling and the crackling stops after doing the factory reset?
    Sorry for all the questions, just need to know the exact details of the issue.
  • You are Wellcome,
    yes exactly, i'm using a 3.5mm to RCA composite A/V cable.
    The sound works great but after using Youtube the sound is still working but the right output starts with crackling.
    A restart dosn't help, only a factory reset helps. I tried twice and deleted YouTube now.
  • Thanks for the extra details.
    Will forward the issue to the developers to see if it can be reproduced and patched.
    Closed the thread.
