Missing android elements
  • Hi there seems to be some omissions from the android 7 included in with the z7+. For a start I needed a way to copy some files from a USB to the sd card. The included file manager has no copy/paste feature so I installed total commander from the play store. This was unable to access the external drive because the system was missing "com.android.documentsui". So how are we to manage files (i.e. move them) on the box?
    The second missing element is that I tried to use an XBOX 360 wireless controller using the PC dongle. This should work out of the box but doesn't.
    Any suggestions/explanations?
