Aktuelle F1 Bug - Meldung / Current F1 Bug -Report
  • Ok, like follow!
    - Il make cut here and move report postings for F3 to proper F3 Bug Thread.
    - Important: Please don`t report Bugs with F3 for F1 and other Boxes, each Box has his own Area. We collect all needed data and the Driver Dev. doe then his job. We need to do this because sometime it`s confusing and only mix of Informations.
    - Postings without reports and feedbacks will be deleted, therefore please use other and proper threads. Clean desk is important ;)
    Here in this thread only F1 Bugs/Reports. Thank you for your understanding.
  • Kindly ask you to fix Formuler F1 CI driver (4.10.6)!
    It didn't initializes properly MPEG-4 DRE Crypt NKE/CASv.3 DRE-3 CAM (always "init module" status in Common interface menu instead of CAM name).
    This CAM properly initialized and working in my VU+ Solo2 box with old firmware (BH 2.1.6 with 3.13.5 kernel); however, ever not initialized on any Formuler F1 image (from factory 2014 to any current OpenATV/OpenPLI/OpenBH/OpenSPA etc.)!
  • There are different drivers for the box
    A: Driver for CI + Support
    B: Driver for transcoding
    You need a images with CI+ Driver and the Plugin CI+Helper
    Both are included in openNFR6.0
    openATV6.0 you need CI+Helper
    For openHDF6.2, the CI + Helper is available on the feed
    Viele Grüße / Best regards
    anmado :)
