Screen format / Aspect ratio
  • One thing I recognized during my initial testing which I found to be a bit annoying is that on some channels it will auto switch the aspect ratio from original 16:9 to some kind of letterbox format which just doesn't look right. I can manually adjust the aspect ratio but when I switch back and forth between channels I have to do it each time again. Is there a way to set 16:9 as the default and to disable the automatic resizing?
    Known issue. Will be patched in the next update.
    Original format will be default and the user-selected custom aspect ratio preference will be saved per-channel.
    Closed the thread.
