Having issue with TvSeries. It doesn’t show the episode series. It only show first episode. Is there a way to see all the episodes? Will there be a new update to fix the issue? Also vod doesn’t show the cover pictures of the files. The icons shows blank.
TV SERIES DOESN’T SHOW EPISODES NUMBER.
With portal/mac this works fine. What do you use xc or m3u?
I m using Portal url.
My mac is
1) not seeing the cover pictures for any VOD file
2) Series doesn’t show up. Only shows and plays first episode.
Admin edit: Never post your ID or mac public!
i am using yyyy server portal as well as yyyy server.
Admin edit: Don't post portal names..
Reported from you is definitely provider issue. Checked both on different two portals, works nice.
I have tried 5-6 servers on the box and none of them shows the tv series. All of them shows the first episode only.
I spoke with server guys also and all of them are saying Formuler company has to send a update to fix it. Tv series works very good on Formuler z7+ boxes and other brands but just doesn’t work on Z8.
same for me...
Tried to reproduce your issue but with portal Vod/Series is all fine on my side. Except the Infos, but TMDB integration will come in future update.
Please see pictures. -
I get info from Formuler that this issue is known and already patched with next mol2 version.
When can we expect new update? This way its hard to use the box. Also i am a seller for these boxes. I won’t be able to sell it before this issue is fixed.
Public pre-release software beta should be released today or tomorrow
Do we need to sign-up for the beta? Or any setting we can swap so we get the option to install it?
In the update app, press 0227 on the remote to activate beta downloads
Great, thanks a lot! Looking forward to testing it and hopefully some of the problems I have with timeshifting will be fixed as well
i just install it and the episodes lists in vod work well!! I like we can choose the group in epg too the only thing for me is i still cannot recording scheduled program from the epg..But thank you for the rest!!
I will also try the beta for the VOD and TVSeries. For me (one providers have no issues, while the other does ). The portal can't help me so hope the update does do the trick
Updated to Beta version.
I am loving this box now. Works perfectly awesome. All the major issues are resolved with this update.
Formuler has Best support team.
Thanks guys.
For me the update did not do the trick.
Stil no pictures on VOD and TV series shows "Empty content"
If anybody have tips, please let me know. As not having pictures is really a big difference.
