Formuler z8
  • Hi everyone I'm just about to get one formuler z8.
    I never had any formuler before.
    I've been reading a lot and see it's a bit of problems going on.
    Epg, audio, WiFi etc
    So can you guys give me some advice?
    And what I need to prepare to?
    Thank you
  • Hello,
    No problems with audio on my side, iptv / youtube / spotify or soundcloud all playing ok.
    EPG works fine for me, programmed recording is not available yet but I am pretty sure its was told before here (search) that it is to be implemented next month.
    I am not using WiFi at the moment, i used it for an hour or so while setting the box up at max router speed on dual band 5G, 8 hundred something mb.
    Wired it goes pretty well, with the ethernet gigabit connection I am getting on internet speed tests 600/575Mb from the Z8 on a 600/600Mb fiber, Ping delay is similar to what i get on a capable PC on the same network.
    Closed the thread.
