Hi
I thought to start a thread where everyone could request additional features (IF POSSIBLE) they would like to see on Formuler Z8 Box.
Hi
One feature i would like to request is while watching anything in VOD and if want to go back to live tv, i would have to exit out from the movie/tv series first then only the live tv button on the remote will take me to the live tv.
It would be very convenient, doesn’t matter which screen or whichever vod i m playing, i press the live tv button and it takes me to live tv right away.
scheduled recording of course my wife cannot leave without it!
search for program name
EPG in different Colors to change
I would like to see an option in MTVOL2 to 'Reload Portal' in the connections settings in the menu.
I would like if possible. Different colours on WiFi simbol when is on and when is off.
Could be white when on and red when off or loosing signal.
Should be 2 different colours.
Thank you in advance 🙏
Option to have time always on.
So time could be showing all the time on or off.
changing portal/playlist do not clear all scheduled recordings.
Coming in next update. Approx. late March
Option to change wallpaper colors in MOL2 will be coming in a future update.
Known request. Will add this somewhere in the menu in a future update.
Display MoreI would like if possible. Different colours on WiFi simbol when is on and when is off.
Known issue. Will try to squeeze it into the upcoming update.
New centralized Recordings/Reminders manager in coming soon.
Scheduled recordings will survive portal change.
hello
Ability to create multiple favorite groups for channels tv and to be able to create favorites in VOD and a section watched recently.
When in live mode, it also starts recorded when you hit the pauze button. So you not first have to press record button before you can pauze.
Genres for VOD and TV (action, thriller ect.ect)
Resume VOD's and TV series
Not a feature but a tip. In some cases in live TV the information display won't disappear in a few seconds and have to press exit manual.
Go into setting and change the OSD time OSD= on screen display
The ability to hide or remove unwanted channels
Is there any chance the adverts can be skipped? This would obviously only work on catch up tv or recorded (once it records).
Keep up the good work!
Still in some cases it will not disappear until you press exit on the remote.
I really like the feature which Z8 have to hide unwanted groups in the portal.
Is it possible to do the same thing for VOD ?? If some people dont want to see various movies group, they will be able to hide it.
Hi i could do with a bit of help i am knew to formular z8 i have switched from
A mag 322 i was wondering how i watch something that was on yesterday i have went back to the time and date I require but when i press ok to watch nothing happens
Hi Lal85. Providing you have catch up included with your service an you added a mag portal an not m3u, I'm guessing the answer would be yes to both, try pressing the Epg button on the remote, have a look at the channel list, do you see a circular icon with a play symbol inside? next too any of the channels? If so they are your catch up channels, highlight the channel, navigate back time/day an select what you want to play. 👍
Will be available in the summer update probably.
The need is known and the feature request is already on the roadmap.
Features I would love to see is the ability to hit any button on the remote at anytime. ie when in the classic or normal guide to switch to the epg guide. Also the ability to hit the menu button at anytime also. Currently you have to back out of everything just to go where you want to go. I forgot to add the ability to hit the info button in any guide.
And, you fix problem? I have same issue.
