Beta Z7+
  • Maybe this post doesn't belong in this thread but since you guys are wondering I'll post it here.
    This is the proposed software change list for MOL1 devices:
    Z-Series April Release (excluding Z8)
    MOL1
    FIX: USB DVB-T Freeview HD EPG issue
    FIX: xtcodes api and m3u favorites
    FIX: USB timeshift file is created if Timeshift is OFF
    FIX: m3u parsing issue
    FIX: Recordings stop when stream buffers
    FIX: Grid EPG cells overlap
    FIX: xmltv EPG parsing issue
    FIX: Video format changes when timeshifting
    FIX: xtcodes api VOD search not working
    ADD: VOD favorites
    FIX: Increased refresh rate of detailed stream info (bitrate)
    System
    FIX: Android Location Services
    FIX: Certain system preferences reset after firmware upgrade
    FIX: Resolution selection window doesn't appear when Resolution button is pressed
    Possibly Z7+ will be updated in mid April but it’s not promised.
  • Last year we had much updates and some betas.
    But from october or november minimal.
    Maby the software is almost good by so far.
    It isn't. Lots of problems with Audio (dts/dd) and still no update for mytvonline. Recording channels gives problems. Pause is horrible (not play from moment you paused it, when you start watching again) , favourites loose when you use a m3u url, etc etc etc, do you want hear more?
  • And again new Off Topic thread. Why is it so hard to keep the direction from thread starter, we are in Z8 Forum discussing Z7+ issues!
    Z8 needed this update to work properly so the priority was higher, but this not means the Z7+ and other boxes are forget, parallel to Z8 and MOL2 is dev. team fixing and working on Z and MOL1 issues. Some mentioned bugs are already fixed. We understand the frustration from some users but this can not be fixed at once for all boxes. Second, so much Community requests and new options flow into new updates and this also need time to implement. Beta for Z7 and others will come 2-3 weeks after Z8 roll out, please be patinate and give the devs. time to make it right.
  • It isn't. Lots of problems with Audio (dts/dd) and still no update for mytvonline. Recording channels gives problems. Pause is horrible (not play from moment you paused it, when you start watching again) , favourites loose when you use a m3u url, etc etc etc, do you want hear more?
    I must be honest to you 160bpma
    You are right.
    Closed the thread.
